asianflava wrote:I made a template out of 1/4in ply and used router to cut my "stud walls" and the faces. I think 1/2in for the template would be better since it gives the router bearing more surface to ride on, but it will be heavier and harder to handle. IMHO 1/4in with 1in foam is pretty thick, especially for a 4x8. I used 1/8in luan for the faces and 3/4in foam in the walls.
markhusbands wrote:couldn't you do the routed plywood frame concept and just skip the MDF template, using the first plywood frame as the template for the other frame and the four skins?
Verna wrote:markhusbands wrote:couldn't you do the routed plywood frame concept and just skip the MDF template, using the first plywood frame as the template for the other frame and the four skins?
The MDF is less expensive than the plywood. So many of those building the tear drops see "things" they want to change after making the template. Since MDF is cheaper, it's not as great a loss if the changes are so great that another MDF template needs to be made.
Woodbutcher wrote:I would suggest making the inner frame work first. Match both to each other. Then attach your skins and trim off the excess with a flush bit (with bearing) in your router. It is easier to use 3/4" plywood for the sides. Much less work and after you make 1 piece to your profile you can match the other using the flush bit. Just a thought.
NathanL wrote:Lot of good techniques but I will say even if you don't get it quite the same you won't notice unless you make one side 6" shorter than the other, or nearly that much.
Go measure car doors on a cars made in the 50's and earlier, even on a car like the '55 Chevy the door lenghts aren't the same with one side being 1/2 longer than the other because the tooling was made from a handmade model.
It's amazing the stuff I have measured that looked "dead on" that was so far out of square and plumb it wasn't funny.
shootr wrote:Couple things:
If I'm using composite construction (thin ply/foam/thin ply with solid wood inserts at key points), I'm not seeing how the flush bit thing works. I want to build insulated because of the temp extremes I intend to use it in - +100degrees summertime and freezing temps in the fall/spring. Is it the consensus that insulated isn't necc.? (I'm not installing heat or AC, our tents never had them and I don't want the hassle/noise/etc. - I'm supposed to be camping!![]()
When people are saying they are using 3/4" ply and skinning it - do you mean 3/4" "ugly" plywood, and a "beauty" skin of luan for looks, with no insulation?
I really appreciate everybody's input - this forum is the most enjoyable I've been on (in any topic)! Thank you all for taking the time to write back.
