pico light
pico light
Postby jb1957 » Thu Sep 13, 2012 11:22 am
My pico light built to plan size except 1/2" floor and double wall sides and roof I built to tow behind my motorcycle
had it weighed 260# will finish with vinel to cover screen
Jim
Brushton ny
jb1957
Re: pico light
Postby wagondude » Thu Sep 13, 2012 12:35 pm
That is pretty sweet. :thumbsup:
Bill
101137
wagondude
Images: 35
Re: pico light
Postby pete42 » Thu Sep 13, 2012 2:57 pm
now that's just nice and cute lil' thing should serve you well..........
pete
pete42
Re: pico light
Postby rmclarke » Thu Sep 13, 2012 3:19 pm
Very nice....more pics please! :applause: :applause:
rmclarke
Images: 231
Re: pico light
Postby jb1957 » Thu Sep 13, 2012 4:59 pm
I am waiting for snaps to finish been fun to build
Jim
jb1957
Re: pico light
Postby jb1957 » Thu Sep 13, 2012 5:06 pm
it tows very easy behind the bike
jim
jb1957
Re: pico light
Postby Lgboro » Thu Sep 13, 2012 7:34 pm
Awesome, first one I've seen built. Really like your camper.
Lgboro
Images: 53
Re: pico light
Postby djoyner » Thu Sep 13, 2012 7:47 pm
jb1957, I am making plans to build a TD to pull behind my Goldwing.
Would you mind sharing your plans, materials list and pics?
I was looking to build a TD that was under 400lbs. and yours seems to fit the bill.
What trailer/chassis did you use.
It looks like you used wood siding.
Thx.
D J
1978 GL1000
1985 GL1200 Interstate
1995 GL1500 Interstate
2006 VTX 1300S
Visit me at: http://www.dennisjoyner.net
djoyner
Re: pico light
Postby Lgboro » Thu Sep 13, 2012 9:43 pm
@ djoyner, just click on DESIGN RESOURCES in the link at the top of the page and then on pico light. You can download plans for a pico light there.
Lgboro
Images: 53
Re: pico light
Postby jb1957 » Fri Sep 14, 2012 3:46 am
I went buy the plans on this site except I used 1/2" for the floor and I used the same 1/4" for inside the plan calls for 3/8" floor
and single wall side I went the screen for better venting the toung I used 1 1/2 x 1/8" angle with a heim joint as a coulper
the box tubing is strong but what the plan called for was so thin wall I thought it would rust from the inside out to fast
and I used FRP panels to cover the 1/8" ply on the roof also I added 1/8 ply on the bottom to make floor stronger and a smoother
air flow the weight extament on the plans is off I came out with a weight of 260#
Jim
IMGP3515 (1).JPG (116.19 KiB) Viewed 422 times
jb1957
Re: pico light
Postby djoyner » Fri Sep 14, 2012 5:45 am
@Lgboro - thanks for the link. I'm still trying to find my way around this wonderful site!
@job1957 - thanks for the additonal information. I think I'm going to use a 4 x 4 HF trailer and extend the floor 2 1/2 ft, so my build may weight a little more than #260. If I can keep the weight under #400, I'd be happy.
D J
1978 GL1000
2006 VTX 1300S
djoyner
Re: pico light
Postby jb1957 » Fri Sep 14, 2012 7:51 am
I think that shell would be strong enough for the extra length with out the extra weight of the HF trailer but if you
have a coupon for the HF trailer it would be less $$ than the torsion axels HF trailer with 14 ga aluminum diamond plate used sears car top carrier about $ 225.00 had a coupon cartop used made the hitch swivel been on the interstate 75+ mph you dont know it is there good luck with your build
Jim
jb1957
