by jb1957 » Fri Sep 14, 2012 3:46 am
I went buy the plans on this site except I used 1/2" for the floor and I used the same 1/4" for inside the plan calls for 3/8" floor
and single wall side I went the screen for better venting the toung I used 1 1/2 x 1/8" angle with a heim joint as a coulper
the box tubing is strong but what the plan called for was so thin wall I thought it would rust from the inside out to fast
and I used FRP panels to cover the 1/8" ply on the roof also I added 1/8 ply on the bottom to make floor stronger and a smoother
air flow the weight extament on the plans is off I came out with a weight of 260#
Jim
- Attachments
- IMGP3515 (1).JPG (116.19 KiB) Viewed 421 times
