Foamie Paddleboard ....
Postby GPW » Sun Sep 16, 2012 12:55 pm
Well, it seems some people just can’t stand for me to sit around and enjoy my retirement :roll: .. Got a request to build Two (2) Paddleboards.. Just recently seen these , just a FAT surfboard 12’ long 38” wide , to (now get this ) stand up and paddle around on ... :NC Foam with a wood center rib , glassed both sides , and a Fin ...
Might be Fun for the younger crowd, and certainly something to bring along camping ... Anybody tried anything like this ??? Seems pretty Easy after building a trailer ... I dunno’ ...
Re: Foamie Paddleboard ....
Postby Fishingtomatoseed » Sun Sep 16, 2012 8:14 pm
Over on http://www.texaskayakfisherman.com/forum/ they have built some and look like they are fun. I would like to try and build one someday................ after the strip canoe and another tear and.......................
Fishingtomatoseed
Images: 9
Postby atahoekid » Sun Sep 16, 2012 9:23 pm
It's a ton of fun and very popular here at the Lake. You can literally pay thousands for a SUP (stand up paddleboard). There are plans for making one out of wood, I've bought the plans and have them rolled up in a corner. No foam involved in the build. Just something else to keep my hands busy. But first, the Road Foamie's gotta get finished.
If you're making one out of foam, I guess the trick is getting the shape right to create the right hydrodynamics. Much like shaping a giant surfboard as GPW said. :thumbsup:
Mel
atahoekid
Images: 158
Postby GPW » Mon Sep 17, 2012 4:52 am
Normally I would have ignored this request , but they offered me Money !!! :shock: A real Job !!! :o
So I went on You Tube , studied up on this ... pretty easy really , since I can carve accurately, but have to do the messy fiberglass thing .... Not a problem ... ;)
Now if I was going to make one for myself (doubtful @ my age ) I might lean to exploring the canvas covering thing ... and maybe play around with the designs .... Looks like Fun :D Here I will be doing something similar to other designs ... One little sticking point ... Trying to figure out how I can do it in His Garage and Not my Studio ... Too messy to have around all my “collectables” , Foam dust would get Everywhere!!! :twisted: .. We’ll have to lay some floor covering/protection down (good chance to try that thick paper we talked about a while ago) ...
Unlike a surfboard , these are pretty Large and Thick (8-10”) , so i was thinking to elminate the wood rib in the center and just beef up the skins on the tension side (bottom ) ... Not going to be used for wave riding , just paddling around and fishing by 50 year olds ... (kids) :roll: As usual strength and lightness will be important ... :thinking:
We’ll see how far this goes ... :thinking:
Postby nevadatear » Mon Sep 17, 2012 7:58 am
There are at least two of them on this board. Tupelosue and netwig.
nevadatear
Images: 171
Postby Wobbly Wheels » Mon Sep 17, 2012 9:25 am
I've got a 12' one at work - if you want, I can grab some pics and measurements to help with your fabrication.
Wobbly Wheels
Postby GPW » Mon Sep 17, 2012 9:42 am
W2 , Yes, that would be very cool !!! Thanks !!! Been checking all the You Tube videos on the subject ... Not hard , but sure is MESSY :shock: :frightened: , and seems to require some specialized tools , that or a LOT of elbow grease with hand tools ... I wonder if it could be ...er, ... Simplified ... I know if I made one for fishing , it wouldn’t be Fancy at all , and maybe even consider a simple outrigger when going after Mr. Bull Red... (Channel Bass) They’d be dragging that board all over the place.. :o
Postby Wobbly Wheels » Mon Sep 17, 2012 10:03 am
No sweat, I'll try and do it tomorrow. As far as chasing Mr Bull Red, you can get inflatable outriggers for canoes and kayaks (aka training wheels). I've got a buddy that uses them on his yak when he's going after springs - they clip into a standard rod holder socket. A creative guy ought to be able to bang something together. You'd need to be able to stow the paddle while you're fishing...
:thinking:
Wobbly Wheels
Postby GPW » Mon Sep 17, 2012 10:23 am
Of course I had to do a drawing ... just something simple for flat-water fishing .. ~40” wide for max stability (sans training wheels :lol: ) 12’ long , 6"-8” Thick ... “rocker” just hot wired in , rails just rounded , that’s it ... :o Or I guess I could glue several sheets of 2” foam together with GG and weight the center between two outer supports for some real “rocker”, then just cut it out... :thinking: Maybe just a simple canvas skin , No FG ...
PB, fishing.png (17.03 KiB) Viewed 1827 times
Postby GPW » Mon Sep 17, 2012 10:36 am
Ooh Ooh !!! Just had an idea :o Just for “Fishing” , cover it with polyester Camo net ... Tough stuff , and hides from the fish ... LIGHT too ...
camo net.jpg (122.86 KiB) Viewed 1825 times
Postby KCStudly » Mon Sep 17, 2012 2:54 pm
+1 on attachment point for the paddle...and the tackle box...and the fishing pole. Little "U"-shaped cleats with two hole anchor points, that way you can use the small spring clips and lanyards for freedom of motion, or even cargo netting.
Don't forget a hand grab/tie down. The rotomold kayaks I've seen use a simple hank of nylon cord with a short plastic dowel or tube as a handle. Gives you something to grab onto when launching or throwing on top of your roof rack, and also a place to tie off in transport.
Went on a few striped sea bass rides myself when yak fishing. Amazing the strength even the smaller schoolies have.
Postby atahoekid » Mon Sep 17, 2012 11:21 pm
I've ridden a couple of boards that have a cut out in the center for a hand hold. Just an oval shape to slide your 4 fingers into. Nothing fancy. I think those are the easiest ones to carry. Tucks under the arm nicely and if the weight is centered, a piece of cake to carry. Nothing awkward about it, just feels normal and natural
Mel
atahoekid
Images: 158
Postby GPW » Tue Sep 18, 2012 5:28 am
Been thinking more about this ... watched a lot of build videos . Not sure I want all that mess in my Studio or yard ... If it’s a Trailer for me , then that’s different ... it’s my own mess eh ... :NC The wife suggested I offer to build them at THEIR house ... That works for me ... :lol: :lol: :lol: Smart woman , the wife ... ;)
For me , I like Rosey’s boat a LOT better ... :thumbsup: :thumbsup: But then , I’m Old and don’t like to get all wet while Fishing ... especially in these BP enriched waters .. :frightened:
Postby GPW » Wed Sep 19, 2012 5:48 am
I should have been a salesman .... :NC Last night I talked with the prospective SUP owners (couple)... Convinced them that fiberglass was expensive , and Messy ... showed them that canvas was the way to go ... Showed them the trailer ... That did it ... Much easier for me ... :thumbsup: And convinced them to do it in their garage and not mine ... 8)
Postby eaglesdare » Wed Sep 19, 2012 6:05 am
you sold me on the foamie idea to begin with! :lol:
Louella
May the foam be with you.
eaglesdare
