New foamie in the works!
Postby redrover465 » Sun Aug 12, 2012 11:11 pm
Hey everyone,
After much research and discussion and more research, we have finally started our 5 x 8 foamie.
:applause: We bought a used trailer July 5 and started dismantling all the parts we didn't need.
Lots of grinding and respraying, but the trailer is good to go, the floor is built and the underside is coated.
Door frames are being made. Here are a few pictures of some of whats been done so far. :pictures:
96751967539675496755
Don and Tammie from Wisconsin
redrover465
Re: New foamie in the works!
Postby loaderman » Sun Aug 12, 2012 11:34 pm
Sorry can't see pics, OK now I can :shock:
Nice start
loaderman
Postby redrover465 » Sun Aug 12, 2012 11:37 pm
Okay, I think I fixed it now. Thanks
redrover465
Postby GPW » Mon Aug 13, 2012 4:23 am
Red , Welcome to the Foamies !!!
Postby pete42 » Mon Aug 13, 2012 6:47 am
I'll add my welcome and will be watching your build.
pete
pete42
Postby atahoekid » Mon Aug 13, 2012 11:17 pm
Welcome to the madness and the fun!!! I'm sure you will enjoy the build. I'm also sure there will be those moments when you question yourself but take a deep breath, have a beverage and keep going. As I near the completion of the Road Foamie, the sense of fulfillment is awesome!!!! Again, welcome to the club and BTW, we love :pictures: :pictures: :pictures: Cheers :beer: :beer:
Mel
atahoekid
Images: 158
Postby bonnie » Tue Sep 18, 2012 6:39 pm
Great start. Looking forward to your build. Welcome!
Remember, the turtle won. :)
bonnie
Images: 107
Postby eaglesdare » Wed Sep 19, 2012 5:15 am
i'll add my welcome also. i think you are going to enjoy this adventure, especially once its done and you are camping! :wine:
Louella
May the foam be with you.
eaglesdare
Postby redrover465 » Sun Oct 28, 2012 7:13 am
:pictures: New Pics finally uploaded!!!
99185Trailer is "remodeled" and coated.
99186Deck is built. We decided to make the trailer wider going with a 5X8 instead. 8)
99187Last minute discussion about the sides led us to bigger than planned doorways, but it all got framed and covered.
99188A few coats of paint on the insides before install to make that easier.
99189Sides are on an looking good!! :thumbsup:
9919199190 Rolling on the foam. We went with a thinner foam for the front and top and eliminated all the cutting to make it roll. By adding some straps while drying we didn't need any scoring.
So this is where we are today. The weather is turning colder and we wanted this finished so it can go back outside and covered for the winter. We're having a few problems getting the canvas to stick to the insides, but we'll figure it out, or Don will figure it out. :applause:
redrover465
Postby redrover465 » Sun Oct 28, 2012 7:18 am
eaglesdare wrote:i'll add my welcome also. i think you are going to enjoy this adventure, especially once its done and you are camping! :wine:
Thanks, love the signature.
redrover465
Postby GPW » Sun Oct 28, 2012 7:30 am
That’s coming along Nicely !!!!!!! :thumbsup: 8)
Check for any thin film attached to the surface of the foam ... some have it , some don’t ... that must be removed before gluing/painting ... I lightly sanded mine a bit to add “tooth” to the surface for better adhesion ... No problems over a year now living outside ...
Another little trick we found was to de-grease the foam , buy wiping the surfaces down with Clean rags soaked with 91% rubbing alcohol (cheap from the Drugstore) .. even oils from your skin can cause problems with paint or glue “sticking” ... Just prep work ...
Postby eaglesdare » Sun Oct 28, 2012 7:43 am
yes a little bit of cleaning the foam might be needed. but it looks like you are trying to get the canvas to stick to the curve? that can be a bit of a pita! i used staples to keep in on til it dried. you have spars there, use them also, staple the canvas to the spars. keep at it, it will come together. thanks for updating us! :wine:
Louella
eaglesdare
Postby redrover465 » Sun Oct 28, 2012 7:59 am
:lady:
GPW wrote:That’s coming along Nicely !!!!!!! :thumbsup:
;) Thanks for the suggestions.
redrover465
Postby redrover465 » Sun Oct 28, 2012 8:01 am
:thumbsup: Thank you also. We are going to keep plugging away at it.
eaglesdare wrote:yes a little bit of cleaning the foam might be needed. but it looks like you are trying to get the canvas to stick to the curve? that can be a bit of a pita! i used staples to keep in on til it dried. you have spars there, use them also, staple the canvas to the spars. keep at it, it will come together. thanks for updating us! :wine:
redrover465
Postby GPW » Sun Oct 28, 2012 8:38 am
Wonder if anybody makes rust-proof staples ? ... then you could just leave them in there ... :thinking:
EDIT: Found em’ ... http://www.amazon.com/Arrow-Fastener-50 ... B001D1FYDI
