My first teardrop - the Kampster, Final Posting
Postby bbarry » Tue Mar 03, 2009 10:50 pm
Juneaudave wrote:Just use a rubber sanding block and a bucket of warm water with a spot of dishwashing soap in it (the soap helps the water flow better). I think you will be pleasantly surprized at how well this works....Dave
:thumbsup: :thumbsup: :thumbsup:
Thanks, I'll give it a whirl and let you know how it turns out!
Brad
Brad
Jack of all trades, master of none.
Kampster build thread
bbarry
Images: 159
Postby greg755 » Wed Mar 04, 2009 8:05 am
Brad,
Just love the interior of your TD. It is a lot bigger than I envisioned.
With that big TV and all those books you'll never get bored in the woods... :R
"It is a cruel thought, that, when we feel ourselves standing on the firmest ground in every respect, the cursed arts of our secret enemies, combining with other causes, should effect, by depreciating our money, what the open arms of a powerful enemy could not." --Thomas Jefferson to Richard Henry Lee, 1779. ME 4:298, Papers 2:298
greg755
Grand Poobah
Images: 65
Postby bbarry » Wed Mar 04, 2009 8:10 am
greg755 wrote:Brad,
:lol: :lol: :lol: :lol: :lol:
Brad
bbarry
Images: 159
Postby bbarry » Sun Mar 08, 2009 6:39 pm
Gave this a try today, smooth as a baby's butt. Then I put another coat of varnish on. I'll be danged if there weren't dust specks all over again! I'll wait for it to dry and hit it with some 400 grit wet then clean it up with a little mineral spirits. That ought to be fine. Thanks for the tip, it definitely helps to keep the sandpaper from gumming up. :thumbsup:
Brad
Brad
bbarry
Images: 159
Postby greg755 » Mon Mar 09, 2009 8:14 am
Sounds like dust in the air.
Close the doors and run an air cleaner for a while...
greg755
Grand Poobah
Images: 65
Postby Nitetimes » Mon Mar 09, 2009 9:04 am
bbarry wrote:
I'm hoping to find a way to mount these on my existing wheels. I'm thinking of mounting a bearing cover onto the inside and using that as an attachment to the hub (rather than the wheel).
Brad
Bad idea....Those dust caps aren't designed to hold anything on but themselves, they seem real tight but a little vibration and a few good bumps and they'd likely pop out. Someone found clips that you can mount to your wheels and snap the hub caps onto...much better idea.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby bbarry » Mon Mar 09, 2009 7:05 pm
Nitetimes wrote:Bad idea....Those dust caps aren't designed to hold anything on but themselves, they seem real tight but a little vibration and a few good bumps and they'd likely pop out. Someone found clips that you can mount to your wheels and snap the hub caps onto...much better idea.
I agree, the clips would be a better solution if I could find them. I'll look around some more...if anyone out there knows where to find them, let me know!
Brad
Brad
bbarry
Images: 159
Postby MsDana » Mon Mar 09, 2009 8:44 pm
Brad Hello! Im new here and am just starting to build. This is really fun so far. Some things just seem like a scavanger hunt. Anyway I want to use moons on my wheels and so if you find a source for those clips let me know. I have some little dimples on my wheels but im not sure if its for caps. Good luck! :moom walk:
MsDana
Postby Nitetimes » Mon Mar 09, 2009 8:45 pm
Brad
If I can remember who it was I'll post it here, in the meantime maybe someone else will.
Rich
Nitetimes
7000 Club
7000 Club
Images: 194
Postby bbarry » Mon Mar 09, 2009 9:11 pm
MsDana wrote:Brad Hello! Im new here and am just starting to build. This is really fun so far. Some things just seem like a scavanger hunt. Anyway I want to use moons on my wheels and so if you find a source for those clips let me know. I have some little dimples on my wheels but im not sure if its for caps. Good luck! :moom walk:
For regular baby moons purchased at autozone, you can do what George did (tap round head screws into the wheel to give the clip something to hook onto):
http://www.tnttt.com/viewtopic.php?t=5625
I don't think that application will work in my case because there is no give (or clip) in the back of the cap. Have fun with your build!
Brad
Brad
bbarry
Images: 159
Postby bbarry » Sun Mar 22, 2009 7:09 pm
Not a lot of news to report, but I've skinned the outer side of the walls and am ready to hook 'em on. Hopefully by this time tomorrow we'll have walls up!
Here's one of our latest diversions: a 1967 Vespa scooter picked up at a local estate auction. As fate would have it, it turns out that it's the same one my uncle rode on as a high school kid (his friend owned it at the time). It hadn't been started in 25 years, but with relatively little tinkering we got it running for a little bit.
Brad
Brad
bbarry
Images: 159
Postby bbarry » Mon Mar 23, 2009 8:23 pm
YAY.....I HAVE A TEARDROP! Or, at least it finally looks a little bit like a teardrop. After spending lots of time working on separate pieces, today many of those pieces came together.
To keep the bubble level:
Sides up, bulkheads in, spars in! Bulkheads made of pine salvaged from the barn, glued and biscuited. Spars are good, clear poplar which I found fantastic to work with. It's a great medium when you want a light paintable wood that's stronger than pine/fir and lighter/cheaper than a hardwood.
My friend Tommy from church put in a few hours of working today...thanks Tommy!
Grandpa seems surprised it's going this well!
It even makes Grandma smile!
Rear bulkhead (with oak header) and galley area.
Vent location framed in. I may have to double up those spars depending on the width of the vent flange.
Gratuitous clampage!
I'm pretty excited to have made this progress today...June is looming closer and closer. My $15 check has been sent, so we're committed to ITG3.
Brad
Brad
bbarry
Images: 159
Postby bigluelok » Wed Mar 25, 2009 1:25 pm
nice build and progress. :applause: my friend has a vespa like yours.
bigluelok
Postby bbarry » Wed Mar 25, 2009 9:46 pm
bigluelok wrote:nice build and progress. :applause: my friend has a vespa like yours.
Thanks (and welcome to the forum by the way!).
Brad
bbarry
Images: 159
Postby bbarry » Mon Mar 30, 2009 7:37 am
Brad
Are these clips what you were thinking of? Perhaps they would work?
Brad
bbarry
Images: 159
