Time to paint the ugly trailer
Postby daveleb55 » Fri Sep 02, 2011 5:48 pm
We are finally at the stage to paint our pop-up conversion. Started sanding the paint off the aluminum base but we can not sand off the decals from Coleman.
Does anyone have any suggestions on how to remove those ugly stripes and Coleman tags?
Thanks
Kathleen & Dave
"Get off the #@$% computer and GO CAMPING!"
daveleb55
Images: 203
Postby 48Rob » Fri Sep 02, 2011 6:43 pm
I'm not sure what Coleman uses for graphics...but generally decals will soften/loosen with heat.
A hair dryer, or heat gun used carefully will usually allow their removal.
You may need to use a solvent when finished to remove the remaining adhesive, as it will ball up and clog sandpaper.
Rob
48Rob
Postby WhitneyK » Fri Sep 02, 2011 7:10 pm
My brother has used a "rubber wheel" decal remover with success. Here's a link to one similar to what he uses: http://decalstickerremover.com/
Not sure how well it will work on "well seasoned" stickers, but just thought I'd throw that option out there for you. Since your not worried about the paint, Rob's idea with the heat gun works good.
Whitney & Tracie
Crothersville, IN
We never really grow up, we only learn how to act in public.
Do not confuse what you hear with what I mean.
My build: http://www.tnttt.com/viewtopic.php?t=41955
160061-------------------------------101114
States we've drug our
li'l camper through. (44 States + Vancouver Island and over 45,000 miles so far)
WhitneyK
Images: 412
Postby hazelc » Fri Sep 02, 2011 9:10 pm
WD40 will remove stickers and bumper stickers. Try that.
Hazel
hazelc
Postby robertaw » Sat Sep 03, 2011 1:55 am
Kutzit!! It will practically fall off 10 minutes after applying it. Of course, it will also remove all the paint and anything else it touches, so only use when you are repainting anyway.
Roberta
robertaw
Images: 56
Postby Pyrofish » Sat Sep 03, 2011 7:38 am
I just did the heat gun/scraper thing on mine. Just don't overheat and it's pretty easy. Someone gave the tip (afterward), that I should have used a chunk of wood as a scraper, and that would have taken the adhesive with it. Instead, once the decals were gone, I tried:
GoofOff (took paint and swirled it),
GooGone (took off the paint),
WD40 (didn't do much of anything),
and Xylene (also took the paint off, but completely off)
Since the Xylene is cheaper in gallon cans, I just used it. You'll need a good aluminum primer for afterward.
Good luck, it's not hard, just tedious :thumbsup:
Pyrofish
Images: 14
Postby robertaw » Sun Sep 04, 2011 12:46 am
Bhix oulc bjj lcvvvbvvvvvvvvvvvvvjjjjjjjjjjjjjjbbbbbbbbbbbbbbbbbbbbbiiiiiiiiiiiiqvvvzx czxlx
EDIT: Sorry, my cat posted that!
Roberta
robertaw
Images: 56
Postby daveleb55 » Sun Sep 04, 2011 1:18 am
Thanks for all the suggestions. We have almost removed all the 25 year old baked in the Las Vegas sun decals the old fashioned way. Elbow grease and sand paper. Now for the paint. :twisted:
daveleb55
Images: 203
Postby pete42 » Mon Sep 05, 2011 9:03 am
robertaw wrote:Bhix oulc bjj lcvvvbvvvvvvvvvvvvvjjjjjjjjjjjjjjbbbbbbbbbbbbbbbbbbbbbiiiiiiiiiiiiqvvvzx czxlx
my cat is to dumb to use the computer you have one smart cat. :lol:
she's just able to use the litter-box................
PS
I don't really have a cat nor a dog or a bird or a fish.
pete42
Postby robfisher » Mon Sep 05, 2011 9:06 am
What do you think you cat is trying to tell us? Could it be a voice fom the other side? I've suspected all t along that cats may be an alien life form and maybe the mothership is about to arrive.
Or maybe it's just her way of saying she's hungry.
robfisher
