I think it’s going to be really Cool !! ... and Not that heavy ...
Wobbly Wheels wrote:Thx Mel.
Yeah, once it's all shaped I'm going to take the panels off the form and glass them flat on the table with a layer of 6oz inside and out. Then I'll hang them back on the form, tape the joints and fair the seams. Then it's another layer of 6oz over the outside to fix everything together and to give it a thicker shell, final filling and fairing, and paint.
I've left the seams unglued where the panels join so I can separate both side walls, the back wall, the roof, the door jamb and the nose into panels small enough to work with. I have to carry them around the house and down a flight of stairs, so it's a good thing it's foam.
KCStudly wrote:Like I've said before, TLAR (That Looks About Right) is a valid engineering principle!![]()
KCStudly wrote:I call it, 'that looks about right' engineering.
Wobbly Wheels wrote:Hey Mel,
BTW, how's your Road Foamie build going ?
Or did you get sidetracked after getting the jockey box in ?![]()
Wobbly Wheels wrote:Haven't checked the thread in awhile...
Next time, I won't use 1/8 as a substrate for the floor on top of the foam. As I've been walking around, I can feel it flexing and I suspect there are areas where I've indented the foam core a bit. Once the cabinets are in, I'll fill the lows, glue down some 1/4" in the traffic areas, and call it a lesson learned.
